Oil leak and will not start
215,000 MILES • 3.8L • V6 • MANUAL
BRANDON GODBEY
  • 5 POSTS
I got into an accident yesterday and now I have an oil leak on the passenger side near the wheel and the car will not turn over. Is there a common problem spot for the oil in that location, and why will not the car start?
Jun 26, 2018 at 3:35 AM
AL514
  • 5,700 POSTS
Hi there, start with the basics; get for power at the starter motor if it is not turning over, you probably have a broken or loose wire.
Jun 26, 2018 at 3:41 AM
BRANDON GODBEY
  • 5 POSTS
I just replaced the starter, battery, and terminals no more then a month ago. It is acting like it is out of gas but it is not.
Jun 26, 2018 at 3:46 AM
AL514
  • 5,700 POSTS
so it is cranking over then? then go back to the basics again, check for spark, fuel and compression
Jun 26, 2018 at 3:55 AM
BRANDON GODBEY
  • 5 POSTS
I know the fuel and sparks are good. How do I check compression?
Jun 26, 2018 at 3:57 AM
AL514
  • 5,700 POSTS
So the car cranks over or not?
Jun 26, 2018 at 4:09 AM
AL514
  • 5,700 POSTS
My guess, if you got into an accident is that you have some broken or crushed wires somewhere. I would start looking around where the car was damaged and check the wiring harness.
Jun 26, 2018 at 4:11 AM
BRANDON GODBEY
  • 5 POSTS
Well, the thing with that is it was not much of an impact, but it was at rear left of the car near the tail light.
Jun 26, 2018 at 4:23 AM
AL514
  • 5,700 POSTS
Okay, so lets be clear here. The car does not crank over right after a crash?
Jun 26, 2018 at 4:25 AM
BRANDON GODBEY
  • 5 POSTS
Yes.
Jun 26, 2018 at 4:34 AM
AL514
  • 5,700 POSTS
If it is not cranking over check for power on the starter wires with the key turned over.
Jun 26, 2018 at 8:21 AM
