Oil and battery lights are constantly on
48,466,953 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
CHAAIZ86
The engine overheated due to a cracked thermostat housing. This caused the non-return valve on the block to melt so I had it replaced plus the cracked housing. I switched the ignition on and the oil and battery lights are still on and my car will not start. Are these lights restricting my car from starting and how do I reset them (if possible)?
Jan 8, 2017 at 6:22 PM
  • 31,937 POSTS
does it crank over or it will do nothing? if it is cranking can you hear it try and start, like a cough or splutter as it tries to fire?
Jan 8, 2017 at 6:24 PM
CHAAIZ86
It cranks like it is coughing.
Jan 8, 2017 at 6:31 PM
CHAAIZ86
It is just like a continuous splutter.
Jan 8, 2017 at 7:41 PM
