oil and water mixing
26,836 MILES • 2.0L • 4 CYL • MANUAL
BRAKKIE
Hi, i have got a problem on my vehicle the water and oil did mix. so I did head gasket pressure test and skim head. Now the van is mixing the oil and water again. not even a week and it is not overheating and i am even driving it. Can there be an oil cooler on it maybe and mixing in there? can anyone help?
Oct 22, 2016 at 10:16 PM
WRENCHTECH
  • 20,758 POSTS
We do not have that vehicle here in the US so I cannot confirm if it has an engine oil cooler but if it does, that most definitely can be your problem. If the oil has a reddish tinge, it could be transmission fluid from a leaking cooler in the radiator.
Oct 22, 2016 at 11:05 PM
BRAKKIE
Its cool I put some wonder weld in and is solved my engineers says there is a crack in block so I throw wonder weld in and its good thanks.
Oct 24, 2016 at 7:25 AM
  • 55,770 POSTS
I have never heard of wonder weld, please let us know if the fix stays good.
Oct 26, 2016 at 3:14 AM
