Oil light comes on
117,300 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
GLI12
Vehicles oil light comes on. Oil is full. Rattles bad but does not sound like lifters. Have video to describe.
Oct 19, 2018 at 11:17 AM
  • 110,248 POSTS
First, if the light is on and there is engine noise (lifters or not), it is a concern. What I suggest is to rent a mechanical oil pressure gauge from a parts store. It will install where the electric one is presently located. Check oil pressure using that gauge to determine if there is a problem with pressure or the oil pressure switch.
If the pressure is low, then it is time to start taking things apart to determine where the noise is coming from, what is worn or plugged and so on.
Also, if you could up load the audio, it may help. It did not attach.
Let me know,
Oct 20, 2018 at 9:49 AM
