Mine is doing the same thing since I put a new thermostat in it.
I found out today there are 2 oil switches on it. One on the filter head and one on the cylinder head.
Check your oil pressure. If it is good one of those switches are bad. You will need to know what color the insulator is. Napa's cost per switch is in the $10 range.
I am going to check mine tonight.
SPONSORED LINKS
Monday, April 21st, 2008 AT 10:09 AM
