Odometer not working continuously once battery is disconnected
2007 MAZDA 6
142,000 MILES
SKRNOOPURAM
  • 7 POSTS
I purchased a 2007 Mazda 6 and I was checking the fuses. After inserting the fuses, the odometer is showing only lines, no any reading. The gear status indication (AT, N, P etc) are also not working.The trip meter, speedo meter, temp. gauge and fuel gauges are not working some times with lines in trip meter and an amber light in the fuel gauge. But sometimes these readings (except odometer and gear indications) are working also. All the fuses are found normal.
Kindly any one give me any solutions.
Sep 28, 2013 at 6:53 PM
  • 31,937 POSTS
This will be a fault with the LED display, the dash cluster will have to be removed and repaired by a specialist in LED dash systems.
Sep 28, 2013 at 7:35 PM
SKRNOOPURAM
  • 7 POSTS
When I opt for the cluster test option by turning the ign. key by pressing and holding the trip button, all the LEDs in the cluster are working and all meters are working. Means all LEDs are fine.
Sep 28, 2013 at 10:16 PM
  • 31,937 POSTS
Do a scan through the body control module and see if there are any fault codes.
Sep 29, 2013 at 7:21 AM
SKRNOOPURAM
  • 7 POSTS
Foe the scan of Body control module, I have to contact a mazda technician, right? Meanwhile which one is the BCU? I hope the one I found down side of steering wheel which is marked as "LFK9 18 9E1C" which was a mitsubishi product is that. Please confirm.
My keyless entry system is also not working. Central locking system is working. Immobiliser is working. Immobiliser flashing light in the instrument cluster is also flashing when the car in off and lock condition. Is this has any relation with the odometer issue? My cigar lighter is also not working. When I checked before, there was voltage with reference to ground, but now a days no. May be these all related to one issue.Please confirm.
Oct 1, 2013 at 7:39 PM
  • 31,937 POSTS
Run the scan with a good scanner, you must do this first, you will be wasting time and money by fitting a new module before testing, the problem may well be in the dash unit, the scan will should help identify what is at fault
Oct 4, 2013 at 9:17 AM
