I have a 1978 Dodge Lil Red Express with the high performance 360 engine. Under acceleration and deceleration everything is fine. When I am simply trying to hold a steady speed (45 mph or so) I get an occasional backfire in the left stack. There is no rhythm to it, Just an occasional pop. The last time I had this I changed the plugs and everything got better. This time changing the plugs did nothing. I also changed the air filter with no change.
Can you tell me the correct timing for this vehicle?
Also, what else could be causing this occasional backfire?
Thank you
Thank you
Sep 17, 2018 at 11:43 PM
