Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Crown Victoria
Engine
Computer
Diagnostic Connector ALDL
OBD port cut
1998 FORD CROWN VICTORIA
100,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ADAMCROWNVIC
MEMBER
Need wire diagram for Police interceptor OBD port. The wires have been cut.
Oct 9, 2019 at 6:59 AM
Experienced Mechanic
Good evening,
I attache a diagram for the connector with wire colors and functions.
Image (Click to enlarge)
Oct 9, 2019 at 9:33 AM
ADAMCROWNVIC
MEMBER
Thanks, but the pink/light blue split into 3 and the tan/orange also split into 3.
Oct 9, 2019 at 11:36 AM
That is the connector diagram you requested.
What specifically do you need?
Oct 9, 2019 at 5:05 PM
ADAMCROWNVIC
MEMBER
The entire obd port and harness is gone. Do you have the entire diagram? That would be a huge help.
Oct 9, 2019 at 11:25 PM
I attached 2 diagrams. The pin numbers are marked and wire colors.
Pin 16 is a power from the fuse box.
Images (Click to enlarge)
Oct 10, 2019 at 2:16 AM
ADAMCROWNVIC
MEMBER
Oct 12, 2019 at 8:25 AM
You are welcome.
Always glad to help.
Oct 12, 2019 at 9:53 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
