Hey JDUNFORD2871,
OBD code P0171 points to fuel system too lean, this would point towards a fuel pressure problem.
If the engine is turning over slowly then trying to boost with jumper cables or a jump pack will rule out a low battery state of charge.
A quick test to attempt to see if the fuel pump has stopped working would be to tap the bottom of the fuel tank whilst someone is cranking the motor. Using a rubber/wooden mallet or something that will not dent the tank. This can sometimes shock the pump and get it going. You then know you have a fuel pump issue.
Let me know how this goes. The next step will be to check fuel pressure.
Do you have access to a gauge for this?
Regards, Joe
Feb 6, 2020 at 8:51 AM
