stops soon after start
150,000 MILES • 5.0L • V8 • FWD • AUTOMATIC
ROB LUNSF
car starts, shuts off, low gas to motor, new filter.
codes po171,po174,po420,po430,
where to go from here?
Aug 12, 2017 at 4:43 AM
STEVE W.
  • 15,418 POSTS
What is the fuel pressure reading with the engine off?
Engine running?
What does the pressure do if you snap the throttle?
Check it over for vacuum leaks. Don't forget the brake booster.
What do the fuel trims show?
What do the O2 sensors read, both upstream and downstream?
Aug 14, 2017 at 8:11 AM
