Not starting on first go every morning
12,000 MILES • 1.6L • AUTOMATIC
TAMARA123
After a few months of purchasing the car and less than 5,000km mileage I noticed that occasionally I had to start a few times on certain days and mentioned it to the Service people. I left it with them and they said they didn't notice a problem with the starter.
But now it has done 12,000km and every day I have to start it a few times each morning. After the initial starting problem it works fine afterwards. Maybe it is after the engine has warmed up. Can you please give me some advice on why this is happening and what could be done.
Feb 17, 2014 at 7:56 PM
SQM
  • 6,383 POSTS
Hard starting can be due to a number of factors.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
As you mentioned it only happens in the morning, it could be a component that is not functioning properly when cold.
Sometime a faulty fuel pressure regulator can trigger this issue. As at cold temperature the internals can have too much mechanical resistance and not allowing sufficient fuel to flow to start the engine.
Testing the fuel pressure could be a good first step. Be sure to test it when it is cold (the typical time you have the no start issue), that way you will know if it is a fuel issue or something else.
Here is a helpful guide:
Jan 11, 2022 at 3:40 AM
