Shut off while driving will not start
200,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
JOWALT
Coming to work and started losing power. RPM started going down even if I gave it gas, Finally shut off and will not start.
Dec 20, 2018 at 3:47 AM
  • 110,248 POSTS
Based on your description, it doesn't sound ignition related but rather fuel related. The first thing I suggest is checking fuel pressure. However, here is a link that discussed the most common causes for a crank no start condition:
Here is a link that discusses in general how to check fuel pressure:
Here are the manufacturer's specifications related to pressure:
Fuel pressure
1. Ignition "OFF" for ten seconds.
2. With ignition "ON," engine "OFF" and fuel pump running, pressure should be 415-455 kPa (60-66 psi).
For additional fuel pressure testing procedures,
________________________________
An easy way to determine if the problem is fuel related is by using starting fluid. If the engine starts for a couple seconds and then stalls, the problem is fuel related.
Do this and let me know what you find.
Dec 21, 2018 at 12:40 PM
