Engine cranks but does not start
80,000 MILES • MANUAL
SUZE07
hi, my car is not starting up. it cranks up likes it's going to and then the fan comes on.
Feb 18, 2021 at 12:18 PM
We need to start with finding out if we have fuel and spark. You need fuel, spark, and compression in order to the engine started so let's assume you have compression for now.
Here is a guide that will help with testing the fuel pressure:
Then we need to pull the plug out and hold it against the block and crank the engine and see if there is spark.
We don't have a manual on this vehicle to give specifics but the idea of this is still the same so let's start with this and we can go from there.
Feb 19, 2021 at 7:22 AM
