A/C compressor replacement
1977 FORD E-SERIES VAN
130,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
MI30189
  • 50 POSTS
Hi Gentlemen,
I have a 1977 Ford E-150 van, RWD, 351w. I have a quick question. The A/C compressor has been broken for years, what would I need to do to remove the A/C compressor and replace it at a later date. I have a new one, and other new parts to replace the other failed parts. I need to know if I have to plug the lines or remove them.
Thank you,
Mark
Dec 3, 2018 at 1:03 PM
  • 110,244 POSTS
The hoses should be plugged to prevent contamination. However, I would replace them. Based on age, miles, and being disconnected, I would replace them. If you do not, the system will need vacuumed down regardless, so it should remove any contaminates.
Dec 4, 2018 at 9:03 AM
MI30189
  • 50 POSTS
Hi Joe, Thank you for the information. I have a new compressor and hoses for replacement. I just wanted to see if I was doing the right way.
Thank you and appreciate your time.
Mark
Dec 5, 2018 at 1:10 AM
  • 110,244 POSTS
Mark:
First, you are very welcome. I just wanted to suggest something. When you put things together, I would replace the orifice. Chances are it is bad at this point.
Take care and feel free to come back any time.
Dec 5, 2018 at 10:59 AM
