Noise from front drivers tire
165,000 MILES
MCULLIN
I am getting a whirring noise from my front drivers side wheel. I replaced the Bearings and it still made the same noise. (to be fair it sounded like bad bearings) I replaced the Calipers and brake pads and the noise is still there.(Good Year said the caliper was pushing the brake all the time and that it had melted and cracked the brake pad) Both times a different mechanic made the diagnosis. What could it be if not these two things? Oldsmobile Alero 6 Cylinder.
Apr 12, 2013 at 5:09 AM
did you replace the one piece hub bearing
Apr 12, 2013 at 8:19 AM
MCULLIN
Yes it was a one piece hub, I also had the tires balanced.
Apr 12, 2013 at 8:34 AM
