noise
80,000 MILES • 5.3L • V8 • RWD • AUTOMATIC
TOMMY1960
about a month ago my truck started making a roaring noise that sounds just like mudgrip tires make on the road,but it's not the tires.it does it all the time except when you turn left,even just enough to go around a curve.i have rotated and balanced the tires and replaced the front brakes,but it still does it.....any ideas? i thought maybe a wheel bearing problem,but can't find one with any slack in it at all.
Aug 28, 2016 at 10:29 AM
WRENCHTECH
  • 20,758 POSTS
Sounds like you have a bad left front hub bearing. They can go bad without having any play.
Aug 28, 2016 at 10:53 AM
TOMMY1960
i guess i'll tear it down and see...thank you!
Aug 28, 2016 at 11:14 AM
WRENCHTECH
  • 20,758 POSTS
The only way you are going to confirm it is to remove the hub from the truck and feel the roughness in your hand.
It's very common on those trucks. It often causes an ABS fault in that wheel also.
Aug 28, 2016 at 11:16 AM
TOMMY1960
thank you very much
Aug 28, 2016 at 12:34 PM
WRENCHTECH
  • 20,758 POSTS
You're welcome
Aug 28, 2016 at 12:36 PM
