No starting, after new battery and new alternator?
110,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JOSHUAABBOTT
My car lights are all on, checked all the fuses, replaced battery and alternator, but when I go to start the engine, it turns over and then stops, sometimes the starter will spin by itself when trying to start it. Like it won't engage to the flywheel. No clicking, I don't consider the noise it makes when I try to start it as a click, it's like it tries to turn over the engine almost doesn't like the engine is seized! I gave someone a jump start, then after they took off, I started to lose power and it shut off and wouldn't start. Now when it shut off before and the security was engaged it wouldn't do anything when I turn the key.
Apr 20, 2024 at 10:30 PM
  • 55,694 POSTS
It sounds like the starter is bad or you have a defective alternator. I can tell what's going on if you upload a short video of the engine when you try to crank it over. Also, it could be a bad positive battery cable.
Here is a guide to help load test the battery so we can rule that out:
This guide may help as well:
I need more information to help you. Please go over these guides and get back to us.
Apr 21, 2024 at 5:39 AM
