No start, new battery
175,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
CANNON1349
  • 861 POSTS
Customer's vehicle started shutting off on the road, and they had to get someone to jump them off and then the car would shut off after. They bought a new battery and when I got to it the starter will turn once, then click, and a popping sound from the speakers will sound and the lights turned off. I've checked the battery fuses.
Jul 15, 2020 at 1:29 AM
Good afternoon,
Did you check the battery voltage? Make sure you have 12.6 volts.
Also, the battery cables, make sure you clean them up inside and outside. It sounds like a bad connection.
Jul 15, 2020 at 2:59 AM
