Code E52, E67 and F40, engine cranks but does not start?
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAODONNE
Engine cranks but doesn’t start, engine code 2A9A.
Replaced crank and cam sensor.
Oct 2, 2023 at 11:56 AM
  • 110,248 POSTS
When cranking the engine, does it sound normal? In other words, do you notice any difference in the sound or speed the engine turns?
I ask because the sensors you replaced are relevant, but there are other things that may be causing the issue. My biggest concern is if there is an issue with the timing chain.
Is it possible for you to record it cranking and upload it for me to hear? I should be able to tell if it is timing-related
Take a look through this link as well, you may find it of interest:
https://www.2carpros.com/articles/car-not-running-advanced
Oct 2, 2023 at 2:07 PM
