I have the car listed above in it this one doesn't have a distributor to it. It's ran by a ignition control module with coil pack no check engine light was running this morning now it wont start it backfires in the crab there many new parts on it seem it out if time not sure because my understanding is it run off the computer and ignition control module for the timing when it was running it'll drive okay couldn't gas it more than halfway or it'll miss out and bog down. I am the 2nd owner of the car I pick it up for $100.00 just to work on just at a lost ATM.
New parts
Map sensor
ECM
Alternator
New air filter
Ignition control module
Spark plugs
Wires
O2 sensor
Valve gasket
Throttle body gasket
Flasher relay
High beam switch
Turn signal switch clock spring
New parts
Map sensor
ECM
Alternator
New air filter
Spark plugs
Wires
O2 sensor
Valve gasket
Flasher relay
High beam switch
May 29, 2021 at 5:02 PM
