No start, I recently just changed my oil pick up tube?
2008 PONTIAC GRAND PRIX
1,360,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
LIONELL8732
  • 150 POSTS
Hello, I recently just changed my oil pick up tube and dropped the pan... Cleaned it up and put fresh oil back in... Once I got everything back together... The car started and I heard some ticking, so I drove it two blocks over and the car completely shut off on me, so I literally had to push the car back home. Once it was home, I put the key in the ignition and the car will not start and I have all light power... Next morning, I took the battery to get tested and they say it was bad so I was like okay maybe this will fix the no start, so I pop that in and crossed my fingers. I literally got nothing, and I still have all light power. So, I went with my next conclusion which was the starter relay... Went and bought that and still no start... Please help.
Nov 26, 2022 at 3:50 AM
  • 110,241 POSTS
I believe this is the one that the starter clicks. Is that correct? Are you planning to replace the engine, or do you want to try to fix the present one?
Nov 26, 2022 at 2:19 PM
LIONELL8732
  • 150 POSTS
I want to try and fix it... Help
Nov 26, 2022 at 2:59 PM
LIONELL8732
  • 150 POSTS
What will I need to do?
  • 110,241 POSTS
I'm getting confused between two different threads with the same issue with different users. Am I correct this is the same person that I was speaking with prior, Lavell 11?
If it is, let's focus on the original post. If it isn't let me know.
Nov 26, 2022 at 4:12 PM
