Crank no start issue
ROBERT RIFFE
  • 2000 VOLKSWAGEN BEETLE
  • 2.1L
  • 4 CYL
  • MANUAL
  • 180,000 MILES
It turns over but will not start. No fire. And the anti-theft is off. Well, the light on door lock quit flashing when I opened the back hatch. Is there a fuse somewhere that could be stopping it from having fire to the plugs? I am new to the VW.
Wednesday, October 9th, 2019 AT 7:55 PM
  • 109,959 POSTS
Welcome to 2CarPros.
Do you have a live data scanner? If you do, can you check to see if there is an RPM signal to the scanner when the engine is cranking? Also, do you hear the fuel pump prime? I will also need the date it was made. There should be a label on the door frame in the driver's door.
Friday, October 11th, 2019 AT 5:07 PM
ROBERT RIFFE
  • 40 POSTS
Will check and let you know. And all I have is a voltmeter. And not sure about fuel pump running. It might be monday evening before I get back to you. Car is at friends house. Thank you
Friday, October 11th, 2019 AT 6:20 PM
  • 109,959 POSTS
Welcome back:
You are welcome. I will watch for your reply.
Friday, October 11th, 2019 AT 8:51 PM
