No start after replacing timing belt and crank angle sensor
140,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
PRIESER19
  • 7 POSTS
I recently put in a new crank angle sensor and changed the timing belt. Got through the security reset, I believe. I pushed the reset under the dash near the blinking red light. Turn on the key, all lights and accessories come on, I hear a click under the dash near the fire wall. Computer? I do not get anything at the starter. Have power to the big wire but not to the small wire when key is turned.
Jan 6, 2017 at 10:10 PM
HMAC300
  • 48,601 POSTS
try another security reset. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jan 6, 2017 at 10:57 PM
PRIESER19
  • 7 POSTS
I am not currently at the vehicle, but I will give this a try when I get back out to it. Thank you for your time!
Jan 6, 2017 at 11:53 PM
HMAC300
  • 48,601 POSTS
also, check ignition two fuse under hood and start fuse in relay block right hand side of dash.
Jan 7, 2017 at 12:09 AM
PRIESER19
  • 7 POSTS
Thank you, I did check those fuses yesterday and all appeared good. I am headed over to the car now, and will try the reset steps. Thanks again
Jan 7, 2017 at 1:48 AM
PRIESER19
  • 7 POSTS
Found the reset, that worked! Thank you for the link! Seems to have a rough idle now? Could I trouble you for thoughts on that?
Jan 7, 2017 at 3:36 AM
PRIESER19
  • 7 POSTS
Put an obd2 scanner on it, reading random misfire. Misfire cylinder six, cylinder five, cylinder four and cylinder one?
Jan 7, 2017 at 3:51 AM
PRIESER19
  • 7 POSTS
Okay will try that, it is a forty five minute drive back to the owner :) Ten minutes to my place though so that will happen first :) just in case. Thank you!
Jan 7, 2017 at 4:20 AM
SATURNTECH9
  • 30,868 POSTS
Your timing could be off on the timing belt was it running rough before the timing belt replacement?There shouldn't be any need for the computer to reset itself.
Jan 8, 2017 at 12:05 AM
