No spark at plugs
330,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
LEWXT
  • 5 POSTS
Hi, My 1990 ea Ford Falcon has lost spark.Have replaced coil and D Module. Cap and Rotor looks fine. What would the next step be? I cranked it with a spark plug on the coil lead earthing the spark plug and it only sparks once.Should it have a constant amount of spark?
I don't know much about these motors but it's a 3.9 CPI.
Any help will be appreciated!
Mar 13, 2020 at 1:23 PM
  • 110,248 POSTS
This vehicle isn't offered in the US, so my technical information is very limited. Does it have a crankshaft position sensor? Have you checked to make sure engine grounds are good?
Take a look through these links:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
____________________
Here are a few links you may find helpful:
Mar 13, 2020 at 3:46 PM
LEWXT
  • 5 POSTS
Cheers for the reply, yes it does. today I got a second hand distributor setup so I will put all of that in when I pulled the dizzy cap off the hall sensor wires looked rough. so I will try this. I'm hoping it is the problem.
Mar 14, 2020 at 2:15 PM
  • 110,248 POSTS
Sounds like a plan. I believe the part you are referring to is the pick up coil. If bad, you will lose spark.
Let me know what you find.
Mar 15, 2020 at 3:29 AM
LEWXT
  • 5 POSTS
Yes something like that. I have spark at the coil.
Mar 15, 2020 at 7:02 AM
  • 110,248 POSTS
Chances are that is the problem. Let me know what you find.
Mar 15, 2020 at 10:46 AM
