Engine not cranking?
11,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
GOBYSKITTEN
My engine will not crank. It is not throwing a spark period. It has 110,000 miles. It does not crank period.
Aug 26, 2024 at 12:44 PM
  • 110,248 POSTS
Most commonly, that is the result of a faulty crankshaft position sensor. When you crank the engine, watch the tachometer to see if it moves slightly. If it doesn't replace the crank sensor.
Also, if you have a live data scan tool, you can check for an RPM signal when cranking.
Take a look through this link and let me know if things mirror what you have experienced:
joe
Aug 26, 2024 at 12:58 PM
