Engine not running
80,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MATTHEW MOATTAR
Hey my name is Matt I have the car listed above and I bought it 2 weeks ago. here is the story: I was driving home and the temperature pinned on the highway and I turned the key off and pulled off the car shut off so I jumped it. starts up right away as I'm pulling into my lot it stops and wont start even after jumping it. so I replaced the spark plugs and the coil. I tested the old coil it was shot so was the relay for the fuel pump. I tested the horn relay and that works. so I plugged it in and it still wont fire. the spark plugs I do not know what to do. when I turn the engine over it has compression so it's turning over. I checked the fuel line when i crank it over there for sure a lot of fuel going in.
Jan 26, 2020 at 12:28 PM
  • 55,858 POSTS
It sounds like the timing belt could have let go.To be sure can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. That way I can tell for sure whats going on.
This guide can help as well:
https://www.2carpros.com/diagrams/plymouth/neon/1996
Jan 27, 2020 at 1:48 AM
MATTHEW MOATTAR
It's not timing related.
Jan 27, 2020 at 3:47 AM
MATTHEW MOATTAR
If it was timing belt there would be no compression because only the crank would turn.
Jan 27, 2020 at 5:02 AM
  • 55,858 POSTS
correct, if the timing belt has jumped it will have no compression and not start. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? Also can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. I need to see the engine cranking over to tell the condition.
Jan 28, 2020 at 2:24 AM
MATTHEW MOATTAR
i got it, it was the camshaft sensor.
Feb 5, 2020 at 10:02 AM
  • 55,858 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Feb 6, 2020 at 2:22 AM
