Engine shut off while driving
267,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
LARRY KREIGER
Was driving on highway engine shut off and will not start. No spark.
Apr 15, 2018 at 7:20 AM
HARRY P
  • 2,292 POSTS
Most likely cause of sudden no spark issue like that is a failed ignition coil or a blown fuse. Have you checked the fuses?
With a coil like yours, I use an in-line spark tester to see if there is anything coming out of the coil. Here is a link to the one that I use: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_3?ie=UTF8&qid=1501325755&sr=8-3&keywords=spark+tester
AutoZone also carriers similar testers for a few bucks more than Amazon's price. If there is no spark coming out of there, then we have identified the problem. Let us know.
Apr 15, 2018 at 12:50 PM
