No pressure in clutch leaking clear fluid
108,000 MILES • 1.4L • MANUAL
STEPH N TERRY
Today whilst driving I went from reverse to first but it would go in the car stalled. I turned it off and back on tried again and the clutch had no pressure in it it was going straight to floor and back up. I got out pushed car to side to see it had started leaking clear fluid. any idea on the parts that may have gone?
Mar 14, 2017 at 7:21 AM
CARADIODOC
  • 34,413 POSTS
There is not much in that system, but you need a live person to look underneath and see where the fluid is leaking from. The most likely suspect is the slave cylinder at the front of the transmission. That has rubber seals that can leak.
Mar 14, 2017 at 10:57 AM
