2004 Renault Megane TRANSMISSION
LEBO123
  • 2004 RENAULT MEGANE
Electrical problem
2004 Renault Megane 4 cyl Two Wheel Drive Automatic
1. THERE IS NO ELECTRICAL CURRENT SUPPLIED TO THE IGNITION COILS, WHAT COULD BE THE PROBLEM?
2. REAR WINDOW NO FUNCTIONING, SOMETIMES IT DOES RESPOND
Thursday, January 22nd, 2009 AT 3:24 PM
DAVE H
  • 13,384 POSTS
Check/clean/replace the CKP(crank position sensor) for the no spark issue. The rear electric windows has a design flaw on the motor of the megane. You need to have the motor replaced it's a common fault on this model.
Thursday, January 22nd, 2009 AT 9:05 PM
