No power to ignition starting or dash (intermittent)
2.4L • 4 CYL • 4WD • MANUAL
HEDALOPE
I am working on a buddies raider and i am loosing all power to the ignition switch. you can drive it down the road and it will randomly loose ignition power. i can restart it with a power probe to the ignition switch and drive back home but it will not have any power to the switch still. it will start up fine the next day or later in the day. i am frustrated because the wiring diagrams are not showing me everything i need. do you have any advise?
Dec 27, 2014 at 11:13 PM
HMAC300
  • 48,601 POSTS
k fusible links in pic probably one only has a couple of strands to it and is breaking contact when you hit a bump
Dec 27, 2014 at 11:18 PM
HEDALOPE
Thank you, I forgot all about the fuseable links. I will replace them andd try driving it.
Dec 27, 2014 at 11:33 PM
