no power except for door locks and lights?
97,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
  • 55,691 POSTS
Yes, I have seen the voltage sensor go out and cause a problem, you should be able to test through it to confirm.
Feb 5, 2026 at 1:43 AM
PAULSTENHOLTZ
  • 29 POSTS
good news i found 2 wires in the harness was bad fixed it and i do have a few more dash lights and door chime working. Do you have anything showing or saying where all the ground wires are located inside and outside. if easier to send my email is paulstenholtz@yahoo.com thanks again!
Feb 7, 2026 at 6:29 AM
  • 55,691 POSTS
Here is the link you need for the wiring.
https://www.alldata.com/diy-us/en
Feb 8, 2026 at 12:39 AM
PAULSTENHOLTZ
  • 29 POSTS
Thanks, i got it downloaded. Also, i was checking continuity on the four wires going to the tipn and when i connected to the ground all four showed continuity, i also tried connecting to the positive and all four showed continuities again. Should this be this way?
Feb 14, 2026 at 12:00 PM
PAULSTENHOLTZ
  • 29 POSTS
hey Ken just replaced a ground wire connected to the starter selonode ,when i hooked up the battery got lot of sparks tested wires and fond continuity from positive cable to any ground sot on the car.
Feb 27, 2026 at 12:19 AM
  • 55,691 POSTS
You should not have sparks at the battery like that so there must be wiring that is damaged to ground. I would do another inspection of the wiring harnesses.
Feb 27, 2026 at 12:40 AM
