No heat
164,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
REBSTRKS1
  • 11 POSTS
Frustrated, flushed core twice good water flow, pulled console door is working properly. good heat from rear core. puzzled, any ideas?
Jan 11, 2017 at 3:48 AM
HMAC300
  • 48,601 POSTS
try pulling fuse in fuse box inside truck. it may be the blend door actuator messing up or a broken blend door. pull for sixty seconds with key on then reinstall it may reset actuator and heat will work. If not check to see if actuator is getting power or not.
This guide can help as well
https://www.2carpros.com/articles/car-heater-not-working
Jan 11, 2017 at 4:04 AM
JOHNNY G.JR
  • 320 POSTS
Check the heater control valve. it is vacuum controlled. move lever on dash and see if control moves and check for vacuum at source and valve.
Jan 11, 2017 at 4:07 AM
REBSTRKS1
  • 11 POSTS
Pulled motor for blend door out working fine. is there a control valve? Hoses go directly to heater core good water flow, water is circulating to rear core good heat from rear, puzzled ?
Jan 11, 2017 at 4:26 AM
REBSTRKS1
  • 11 POSTS
Vacuum canister under dash near blend door motor, is this a control for water flow ?
Jan 11, 2017 at 4:32 AM
HMAC300
  • 48,601 POSTS
no, it is a storage for the vacuum. if blend door actuator is getting power then it should open the door unless it's broken. if this is automatic temperature control it needs to be scanned for codes to see what is wrong.
Jan 11, 2017 at 5:01 AM
REBSTRKS1
  • 11 POSTS
Yes, automatic temperature, blend door is working fine. Thank you!
Jan 11, 2017 at 7:31 AM
JOHNNY G.JR
  • 320 POSTS
How was core flushed? hoses left connected to heater core, water run in one hose and out the other. Are both hoses getting hot while running?
Jan 11, 2017 at 1:43 PM
SATURNTECH9
  • 30,869 POSTS
See if both heater hoses are getting too hot to hold? Are you sure the blend door is actually moving? the blend door shafts break and you see the actuator moving but the blend door itself is not moving.
Jan 11, 2017 at 2:26 PM
REBSTRKS1
  • 11 POSTS
Removed both hoses, used garden hose on both sides, flushed both directions with air first then water good flow with water, turned blend door with screwdriver works as it should, actuator is working air moves from vent to defrost to floor, good heat at rear core, hoses get warm but not hot to both front and rear hoses. new thermostat two months ago, puzzled wondering about water pump. is it possible it is circulating enough to not overheat but not enough pressure to push through hoses for front heater core? liquid takes the path of least resistance, I think I will try looping the rear hoses to see if this helps and will force the fluid through the front core only.
Jan 11, 2017 at 10:17 PM
SATURNTECH9
  • 30,869 POSTS
The actuator that goes from floor to defrost is not the blend door that is the mode door. the door adjusts the the temperature from hot to cold.
Jan 11, 2017 at 10:38 PM
SATURNTECH9
  • 30,869 POSTS
There is your heater valve. I posted a picture of it.
Jan 11, 2017 at 10:44 PM
HMAC300
  • 48,601 POSTS
guys, it automatic temperature it may be a sensor bad. see pictures on how to enter and exit self test for automatic temperature control then get back with codes if any. also, check for vacuum leaks at vacuum motors.
SATURNTECH9
  • 30,869 POSTS
I posted a picture if the blend door actuator. It still has coolant going in and out of the heater core blend door actuator etc.Those are basic checks ether way it is automatic or manual controls.
Jan 11, 2017 at 10:48 PM
JOHNNY G.JR
  • 320 POSTS
Is engine reaching normal operating temperature? Are heater hoses free of obstructions? Is return side heater hose collapsing possibly? Is heater valve opening completely? I think HMAC is on to the cure REBSTRKS1.
Jan 12, 2017 at 2:09 AM
REBSTRKS1
  • 11 POSTS
No heater valve. heater core comes through firewall hoses hook directly to core. cannot find a heater valve unless it is behind the firewall, but hoses hook directly to core? Hoses are warm so the water is circulating, but no heat to cab. I have tried everything you have mentioned. that is what is so frustrating!
Jan 12, 2017 at 3:38 AM
SATURNTECH9
  • 30,869 POSTS
The hoses going into the heater core are too hot to hold? Also, are there any codes?Let's put that to bed right now? Also, your sure the blend door is actually moving and the actuator is not just moving a broken part of the blend door?
Jan 12, 2017 at 4:41 AM
SATURNTECH9
  • 30,869 POSTS
The shaft on the blend doors do break, it is not uncommon for them to break. They even make a repair kit so you can fix it through your glove box so you do not have to pull the heater box.
Jan 12, 2017 at 4:43 AM
REBSTRKS1
  • 11 POSTS
I Thank You all for the help, still puzzled, tried every thing I can think of, OK flushed heater core twice good water flow and no leaks, hoses getting nice and warm as they should, looped hoses to rear core to ensure water is flowing through front core, pulled console out actuator motor working fine, turned blend door with stubby screwdriver it is diverting air to floor,vent,defrost as it should, controls for automatic seem to work fine, no codes coming up on self diagnoses, I had to step back and think about this awhile ( also have good vacume at canister and no vacume leaks ) wondering about separate door other than blend door ? Is there a separate door to let air flow across heater core ? Any ideas Thanks again everyone I appreciate the help
Jan 13, 2017 at 7:54 AM
HMAC300
  • 48,601 POSTS
you did the wrong actuator, the blend door moves air across heater and or a/c have a pro look at this.
Jan 13, 2017 at 8:28 AM
REBSTRKS1
  • 11 POSTS
NO I Don't give up that easy, and did a pro learn by giving up
Jan 13, 2017 at 9:28 AM
SATURNTECH9
  • 30,869 POSTS
The blend door actuator is behind the center of the dash.
Jan 13, 2017 at 11:19 AM
REBSTRKS1
  • 11 POSTS
Do you have to pull the dash, or is this the one they say to pull the glove box to get to easier?
Jan 13, 2017 at 11:54 AM
REBSTRKS1
  • 11 POSTS
There is a vacuum canister is it vacuum controlled?
Jan 13, 2017 at 11:57 AM
SATURNTECH9
  • 30,869 POSTS
No it's a electric actuator and the glove box part is if your replacing the blend door with the dorman repair kit.
Jan 13, 2017 at 11:59 AM
SATURNTECH9
  • 30,869 POSTS
Should be able to see it to the left side of the glove box up under the dash
Jan 13, 2017 at 12:00 PM
REBSTRKS1
  • 11 POSTS
Ok I will find it, that has to be the problem, it's the only thing that makes sence THANK YOU
Jan 13, 2017 at 11:56 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome make sure you check the shaft of the blend door to see if uts broken
Jan 14, 2017 at 12:24 AM
GINAMILLER
The heater isn't blowing out any heat. I am researching and I keep finding its my heater core is what keeps popping up but the truck never over heats. with my experience with vehicles is that a heater core blows out steam through the defroster vents and then heats up the engine real fast. stuck we just got this SUV too. stumped.
Oct 16, 2018 at 6:14 AM (Merged)
first, check the heater hoses at the core. they both need to be hot. if one is hot and one cold, the heater core is clogged.
if they are both hot, then the blend door motor has failed.
GINAMILLER
Ok if its clogged how do i fix it do i just replace the core? And if its the blend door how do I fix that. I dont trust many mechanics in my town. If I can do it I will.
you can flush the heater core by using a garden hose and flow both ways.
the blend door motor is much tougher.
NEWTON_S_83
1999 Ford Expedition Four Wheel Drive Automatic 130000 miles
Hi. I have a 1999 Ford Expodition and the A/C works great, but when you switch it over to the heater it still blows cold air. I was woundering if you could help me. I;m guessing its the theromstat or the heater door not opening. not sure.
LEGITIMATE007
  • 5,121 POSTS
yes it is more than likely a mixing door . and they will have to take the dash apart. but I would definitely get several opinions. the dealer is very very expensive and you could save several hundred dollars, going elsewhere. so check it out.
EXPO
Warm up car turn the heat on then it blows hot air then immediately turns cold.
RIVERMIKERAT
  • 6,106 POSTS
Feel the heater hoses at the bulkhead when the engine is hot. Both hoses should be hot. With the engine running, move the temperature control lever/**** completely both directions. You should hear the blend doors in the airbox moving. If not, check the connections, wiring, and vacuum lines. Make sure the vacuum lines are drawing a vacuum. If so equipped, make sure the heater control valve just inside the engine compartment is operating properly when the temperature control is moved. Make sure the cooling system is full and the thermostat is operating properly (look in the radiator with the engine one and at temperature-this will also tell you if the water pump is working properly).
RJSTES
When is heater **** is all the way to heat with high fan it blows cold air.
SATURNTECH9
  • 30,869 POSTS
The first thing i would do is make sure both your heater hoses going into the heater core are getting really hot when the engine is up to normal operating temp.
BUBBLES6785
my heater will not get warm...
no, and I believe I just addressed your heat issue.
ALEXHOLEINONE
What can a backyard mechanic do to fix or replace the heater core. How can i disconnect the power for my heater core for the mean time, till i am ready to have it fix....
