No fuel getting to throttle body
109,000 MILES
KATSFIVE
No fuel is getting to the throttle body, the fuel pump is working. Tested the fuel pump relay, ohms are low.Wanted to know if I can bypass the asd for testing and what am I missing here, What could cause the problem??
May 21, 2013 at 6:42 AM
HMAC300
  • 48,601 POSTS
just replace the asd with a like relay test PRESSURE of fuel not whether it is getting there or not. TBI it should 13.5-15.5 psi if mpfi it should be 46-50 psi
May 22, 2013 at 1:01 AM
KATSFIVE
How do I test the pressure ??? That is something I have never done.
May 22, 2013 at 7:02 AM
HMAC300
  • 48,601 POSTS
This guide can help
May 22, 2013 at 8:17 AM
KATSFIVE
I replaced the crankshaft angle sensor fix it! Thanks for the help :)
Jun 4, 2013 at 4:31 AM
HMAC300
  • 48,601 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Jun 4, 2013 at 5:02 AM
