While stopped at a stop sign the engine shut off, it will crank but does not start?
1996 CHEVROLET CHEYENNE
144,000 MILES • 5.7L • 2WD • AUTOMATIC
CUTIEBUTT12
Stopped at a stop sign and engine immediately cut off. Turns over but will not start. Connected my OBD tool and it mentioned 02 sensor, spark plug, and crankshaft position sensor when I tested the crankshaft position sensor it was basically no good but I don't quite understand how because it never got hit so it should have been fine, but I went and got another because it was still under warranty. But before I changed it, it sounded like it wanted to start, when I changed it there was no fire.
Feb 29, 2024 at 6:58 PM
  • 110,244 POSTS
Chances are it is the sensor. In most cases, a crank no start condition is the result of either an ignition-related component (crank sensor, spark plugs in this case) or it is a fuel-related issue.
The first thing I would do if I had the vehicle would be to simply see if it starts using starting fluid. If it starts and then stalls, we know it is a fuel-related issue. If there is no change, then suspect ignition spark at the plugs is lost likely due to the sensor.
Check these things and let me know what you find. Here is a link that explains how to test for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, take a look through this link and let me know if you feel it mirrors what you have experienced:
Mar 1, 2024 at 12:21 PM
