1996 Chevy Cheyenne will turnover but wont start
BRIAN W AN I
  • 1996 CHEVROLET CHEYENNE
  • V8
  • 287,951 MILES
I drove my truck the day befour yesterday everything was fine now this morning it won't start its getting gas bot won't fire up
Sunday, September 19th, 2010 AT 10:03 PM
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, September 24th, 2010 AT 7:18 AM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
