No crank/start no check engine light on
84,000 MILES • 4 CYL • AUTOMATIC
SARA PAYNE
Hello, I am so close to giving up. I got this car from a friend of mine. The mechanic said it was the ECU and had it replaced. When he went to the dealer they reprogrammed the new one and said it would not start because the battery was bad. My friend released the keys and it started and drove back home but once he shut it off it would not start again. Everything comes on like it is going to start. I got a new battery but it only clicks once when I try to start it. All lights come on except the check engine light. I hooked up a scanner thing from Wal-Mart(cheapo) and it says no communication with ECU/PCM but says compression good and N/A on almost everything else. I think it may have worked for a minute but my be touched the fuse box under the hood and it says lost communication now. The check engine light still never showed before but the OBD tool connected to it at least. Please what could it be? Also, the airbag symbol flashes a few times when I turn the key and power steering message displays. Sara
Nov 21, 2018 at 10:26 PM
  • 110,248 POSTS
If you are only getting one click when you try to start it, it sounds like a bad connection. Most commonly, the battery cables are to blame. They can be loose, corroded, the negative battery cable can be loose where it bolts to the engine block and so on.
With that being said and where the diagnose should start, take a look through these links. Follow the directions and let me know the results.
I will watch for your reply.
Nov 22, 2018 at 10:29 AM
SARA PAYNE
Thanks so much. I will try this now. Would the battery cable problem cause the loss of communication and check engine light to not appear also? Or is that something else? I have not noticed a change in the lights dimming or anything when I turn the key.
Nov 24, 2018 at 5:12 AM
  • 110,248 POSTS
Welcome back:
Honestly, you would be amazed with what a bad ground can cause. Everything electrical on the vehicle needs a good ground. Since you are only getting a click, I have a feeling the ground is the problem or you have a bad starter.
However, if you find no problems with the ground or battery connections, I want you to check the starter itself. Here is a link that shows and explains how it is done. By doing this, we can determine if the problem is simply a bad starter.
The check engine light should turn on when you first turn the key to the on position and may shut off after a few seconds. If it does not, again, my first suspect is a bad ground. I can provide wiring schematics for the data link connector if you need them.
Let me know what you find. Again, make sure the ground wire to the engine block is clean, tight, and in good condition.
Nov 24, 2018 at 7:34 AM
SARA PAYNE
Okay. The battery connections are good and that big red fuse by it is not blown. The starter is new and the check engine light does not come on at all. Ever. I did get it to turn over by jumping the starter thing (I do not know the real term. lol). The OBD scanner says code U1001 or something like that which is no communication with ECM/ PCM. The only other things it says is MIL on and compression good. All else is N/A.
Nov 25, 2018 at 3:58 AM
  • 110,248 POSTS
Welcome back:
Please confirm that it is a U1001. If it is, recheck all fuses in the under hood fuse box. If that is the code, there is an open circuit between the car's computers. It will not be easy to find.
Let me know,
Nov 25, 2018 at 8:52 AM
SARA PAYNE
Nov 26, 2018 at 1:39 AM
