2008 Chevy Cobalt check engine light
44,000 MILES • 4 CYL • FWD • AUTOMATIC
KRISTIMAC2004
My check engine light is on, but not flashing, what could it be. Also, why does the engine sound like it's whining?
Nov 24, 2009 at 9:38 AM
  • 31,937 POSTS
Hi there,
A check light may or may not flash, but you will have to get a scan done to check the fault code that is indicated by the light. As for the noise, it may be a faulty bearing on the alternator, water pump. A/c or a idler pulley, a mechanic should be able to listen to this and advise you.
mark (mhpautos)
Nov 24, 2009 at 9:47 AM
