I have some mystery problems with my little truck. It has a z24 engine, and It has a new starter and a good battery. I had it idling rough for 15 seconds a while ago, but the engine will not even turn over now. My guess is a fusible link, or a faulty switch. The radio plays, and I have even tried to jump start it! Still, there is nothing. Also, I went from having a clutch pedal, to having a pedal with no resistance. This happened while I was attempting to crank the vehicle. The engine did not turn over, and the vehicle did not move either! The fluid level is full, and fluid is coming from the reservoir to the master cylinder. I was told there has been a clutch put in not long before I bought it. I will bleed the dampner for the clutch, and perform more electrical tests after the rain. I am hoping you may have shortcut tests to speed up the repair.
Nov 21, 2013 at 9:46 PM
