no click no start
2012 RAM 1500
175,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
CHARLES MASON2
  • 7 POSTS
I have the truck listed above ST model. it started with lack of power and misfire so i ran a obd 2 and it came up with multiple misfire on bank 1. i changed the plugs and wires 2 coils, also the crankshaft position sensor.I tried to start it but it just clicked. dropped the starter and bench tested it, it was bad.bought a new starter and put it on. now it doesn't make any sound. i checked all fuses and relays, they where good, checked volts to the starter, it was good.
Feb 3, 2020 at 12:36 PM
JOETECHPRO
  • 705 POSTS
Hey CHARLES MASON2,
Can you please check that you have power to the trigger wire is present when the key is in the crank position?
We have a guide for this issue in the link below which will run you through the process.
Let me know how you go.
Regards, Joe
Feb 3, 2020 at 11:52 PM
