No brake pedal when engine runs
900,000 MILES • V8 • 2WD • AUTOMATIC
68GTCS
Power front disc rear drum. I get super soft pedal to the floor, when not running, start the car and the pedal goes straight to the floor. I recently replaced everything because it did this before the final put together after paint and body. Help
May 12, 2017 at 9:10 AM
CJ MEDEVAC
  • 11,000 POSTS
This is about all I have to offer, other than a defective master cylinder
Going give you a link/ there is a link inside of it (lemme know if you do not understand the 'on vehicle' bench bleeding-That's in the link inside of this one)
https://www.2carpros.com/questions/1998-ford-f-150-cant-get-brakes-bleed
Return here with good news!
The Medic
May 12, 2017 at 12:46 PM
  • 55,770 POSTS
Check the bleed and adjustment of the shoes at the rear. Also if the master and booster have been off or replaced check the adjustment of the push rod into the master cylinder.
Here is a guide that might help you.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Cheers, Ken
May 13, 2017 at 11:54 AM
68GTCS
Thank you gentlemen for great advice, the only thing I have not checked it the power booster
rod adjustment.
Also my problem gets extreme no brakes when I start the car and the vacuum line is hooked to booster. Rod? Booster? Mc?
This actually happened before I replaced everything but rear wheel cylinders
May 15, 2017 at 1:24 AM
  • 55,770 POSTS
The wheel cylinder could be causing all of your problems becasue they can let air into the system. I would start by replacing them.
Cheers, Ken
May 16, 2017 at 4:57 AM
68GTCS
Hello ken, I did replace the wheel cylinders now, one did look bad, got excited because I hoped that was it, I put new shoes etc as well, but...still soft pedal and when car is started the pedal Gascony nothing at all. Goes straight to the floor, there was a parking brake link rod missing on one side??.
Anyway am I back to Mc? And maybe rod adjustment?
Thank you
May 30, 2017 at 10:50 PM
  • 55,770 POSTS
Please remove the master cylinder to check the push rod. It sounds like you are not getting all of the air from the system.
Follow this guide and try it again.
Cheers, Ken
May 31, 2017 at 6:25 AM
68GTCS
What measurement, or adjust rod out or in? Thanks
May 31, 2017 at 8:26 AM
