1991 Ford Mustang brake pedal goes to the floor!
1991 FORD MUSTANG
126,000 MILES • V8 • 2WD • MANUAL
JAMESPERRY89
I've replaced just about everything I can. Still, my brake pedel goes to the floor. I have replaced the brake booster, master cylinder, brake proportion valve, brake lines, rear master cylinders, front calibers and bled my brake lines. None of this has helped. The pedal is hard, but still goes completely to the floor.
Jul 8, 2009 at 2:57 PM
  • 31,937 POSTS
Hi there,
You may have a faulty new master cylinder,this is not that uncommon, try this first, get 3 brake hose clamps and clamp off all brake hoses, check that the pedal is hard & high, if not the master is at fault or there is still air in the lines up stream of the clamps, if pedal is hard the problem is down stream of the clamps.
Mark (mhpautos)
Mar 11, 2021 at 6:24 AM
