No brake fluid to back brakes
150,000 MILES • 2.3L • 2WD • MANUAL
DEEDDG
No brake fluid to back brakes, could not bleed rear brakes? Fluid at master cylinder, none at line junction over differential. Guess I crack every connection from front to back until I find stoppage.
Aug 27, 2018 at 9:24 AM
  • 110,248 POSTS
Chances are, there is no blockage in the steel lines unless one was bent or pinched shut. If there is no pressure, there is a good chance the master cylinder (MC) is bad. In the MC, there are two plungers (or pistons) which distribute fluid. One is for the front and the other is for the rear. If there is no pressure, disconnect the lines at the MC and see if both ports produce pressure. I have a feeling the rear one will not.
Apr 14, 2021 at 3:35 AM
DEEDDG
They both put out pressure. There are three places the went flex/rubber, I will see is I get fluid past those. I have had cases of collapsed rubber/flexed brake lines in other vehicles.
Thanks
  • 110,248 POSTS
Let me know. And yes, the rubber hoses can collapse inside and cause this type of issue.
