1994 Ford Ranger brakes
1994 FORD RANGER
WORKMEN40
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
front brakes getting fluid but back brakes are not
Aug 2, 2010 at 4:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check brake lines ensure none are leaking or clogged with dirt/rust.
Aug 2, 2010 at 4:23 PM
WORKMEN40
can i ask you question what does the abs hydraulic unit do. thanks for your help too.
Aug 2, 2010 at 5:07 PM
WORKMEN40
also can the abs hydraulic unit be reset
Aug 2, 2010 at 5:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the ABS hydraulic modulator has solenoid valves for each brake circuit. basically it is used to control brake pressure of the ABS when the ABS is engaged.
Aug 2, 2010 at 5:17 PM
WORKMEN40
thank you for the help.
Aug 3, 2010 at 9:49 AM
