No third gear
NOT PERFECT
  • 16 POSTS
No Roy. I wish I did have an obd2 scanner.
Friday, June 7th, 2019 AT 8:51 AM
  • 52,797 POSTS
At this point, you need to have someone look at it and see the live data around the sensor to see if it is getting the proper commands.
Friday, June 7th, 2019 AT 9:01 AM
NOT PERFECT
  • 16 POSTS
Thank you for all your help. I am done chasing wires and grounds etc. Your help has been greatly appreciated.
Friday, June 7th, 2019 AT 9:04 AM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Friday, June 7th, 2019 AT 9:46 AM
NOT PERFECT
  • 16 POSTS
Well rebuilt the entire transmission still no third. Everything was toast, the converter went. It even broke the bell housing. So after I was finished it leaked like crazy. Are my shift solenoid's bad?
Sunday, June 23rd, 2019 AT 9:09 PM
  • 52,797 POSTS
Okay, did you air test each clutch pack before you completed assembly to be sure the piston and seals were good?
Is the check engine light on? If it were a solenoid, it would set a code.
Monday, June 24th, 2019 AT 2:34 AM
NOT PERFECT
  • 16 POSTS
Hi Roy, no I didn't air test anything but this would be the second transmission doing the same thing; no third gear. I have tested speed sensor wires all good, but still no signal from speed sensor.
Monday, June 24th, 2019 AT 2:10 PM
  • 52,797 POSTS
Okay, how do you know there is no signal from the speed sensor?
You could have a cracked piston in the third gear clutch. That's why I asked about the air test.
Did you replace all clutches and seals in the transmission?
Monday, June 24th, 2019 AT 2:13 PM
NOT PERFECT
  • 16 POSTS
Well, figured out my transmission issue. Be careful the two sensor wires are the same for speed sensor. Switched them it shifts perfect. Thanks for all the help. I will never rebuild a cd4e again. Lol
Tuesday, June 25th, 2019 AT 12:30 PM
