Nissan Xterra Brake Pads Wear Fast
DAISYAIM
How many miles should you get on the average brake pads? Lets say the rotors are good, and you are not brake crazy..... rough estimate anyone? How about the replacement of the rotors in the front? just a guesstimate
Sep 11, 2007 at 10:27 AM
MERLIN2021
  • 17,250 POSTS
A truck your size maybe 30,000 on a premium set of pads. The problem with rotors today is manufacturers are more concerned with wieght reduction for fleet mileage, so they make the rotors thin, Not you father's rotor! A lot of times you can't machine the rotors because of this. Sometimes you can, The shop down the street from me doesn't machine anything anymore, I brought my own lathe bits with me to use his lathe!
Sep 11, 2007 at 10:41 AM
DAISYAIM
ok so 11,780 is not normal for metal on metal? its only been 7 months...
Sep 11, 2007 at 11:13 AM
MERLIN2021
  • 17,250 POSTS
Not normal no, but if the caliper siezed it can happen. Brakes that are partially locked up, can wear out in days! Check the brakes system thouroghly!
Sep 11, 2007 at 11:56 AM
Suggested Repair
Inspect the brake system thoroughly, especially for a seized or partially locked caliper that can wear pads to metal quickly. Modern rotors are often too thin to machine and may need replacement.
Conversation Summary
The owner asked about typical brake pad life and front rotor replacement on a Nissan Xterra with good rotors and normal driving. An expert estimated about 30,000 miles on premium pads and noted that modern rotors are often too thin to machine. The owner then reported metal-on-metal wear at 11,780 miles in seven months. The expert said that is not normal and that a seized or partially locked caliper can cause rapid wear, so the brake system should be checked thoroughly.
