2001 Nissan Xterra Brake Shake and Pull
LMCFERSON
I have a 2001 Nissan Xterra XE 6-cylinder with 76,263 miles.
I have noticed a slight pulling and shaking to one side when I put on breaks. Now my steering wheel is shaking left to right when I drive. When my speed is over 60 mph it evens out to a slight tremble, but when I slow down it really shakes.
Do I need a front-end alignment, tires rotated, or new tires? Thanks.
Feb 19, 2007 at 6:26 AM
CHEVY22
  • 1,375 POSTS
hi ,
sounds like you may have what we call a brake pull which may be caused by a sticking brake caliper , the shaking goes hand in hand , if the caliper is sticking it will overheat and warp the rotor(s), have the brakes checked and repair as needed
thanks
Feb 19, 2007 at 6:51 AM
Suggested Repair
Have the brakes inspected for a sticking caliper and warped rotors, and repair as needed.
Conversation Summary
The owner of a 2001 Nissan Xterra reports slight pulling and shaking when braking, plus steering-wheel shake that is worse at lower speeds and eases above 60 mph. The expert says this may be a brake pull from a sticking caliper that overheats and warps the rotors, and recommends checking and repairing the brakes as needed.
