1995 Nissan Truck Valve Clicking
SNEEKY007
i got a 1995 nissan truck. 115000 miles, 3.0 v-6, auto. i just changed the timing belt. it runs good and doesnt miss a beat. the gas milege kinda sucks, and i here a lifter or valve clicking alittle bit on the left side. do i need to adjust the valves, or is it normal. and if i adjust them what is the gap?
May 2, 2007 at 5:02 PM
  • 75,988 POSTS
[quote:43599d33f7="sneeky007"]i got a 1995 nissan truck. 115000 miles, 3.0 v-6, auto. i just changed the timing belt. it runs good and doesnt miss a beat. the gas milege kinda sucks, and i here a lifter or valve clicking alittle bit on the left side. do i need to adjust the valves, or is it normal. and if i adjust them what is the gap?[/quote:43599d33f7]
You can tighten the Rocker arm nuts and pivot locknuts at 12-16ft lbs. don't work change the lifters.
BTW they do make noises at that age.
May 2, 2007 at 7:35 PM
Suggested Repair
Tighten the rocker arm nuts and pivot locknuts to 12-16 ft-lbs. If the clicking remains, replace the lifters. Some noise is normal at this mileage.
Conversation Summary
Owner of a 1995 Nissan truck with a 3.0 V6 reports slight left-side lifter or valve clicking after a timing belt change. The truck runs well but fuel economy is poor. Expert advises tightening rocker arm nuts and pivot locknuts to 12-16 ft-lbs, and replacing the lifters if that does not stop the noise, noting some noise is typical at that age.
