1994 Nissan kingcab d21 102,000 miles - 4-cylinder - 5 spd manual
Having trouble intermittently with the interlock sytem in starting the engine. Adjusted clutch and interlock switch height. It worked fine for awhile, now it doesn't seem to matter if switch is engaged or not. Have to jump start the vehicle at the most inopportune times. I tried to jumper the wires to simulate a closed circuit, but still no luck. Is there anyway to jumper completely around the interlock system so I don't have to mess with this problem? Under the dashboard is a difficult place to work.
CRT
CRT
Sep 10, 2007 at 3:12 PM
