1994 Nissan D21 Starter Interlock Fix
CRT
1994 Nissan kingcab d21 102,000 miles - 4-cylinder - 5 spd manual
Having trouble intermittently with the interlock sytem in starting the engine. Adjusted clutch and interlock switch height. It worked fine for awhile, now it doesn't seem to matter if switch is engaged or not. Have to jump start the vehicle at the most inopportune times. I tried to jumper the wires to simulate a closed circuit, but still no luck. Is there anyway to jumper completely around the interlock system so I don't have to mess with this problem? Under the dashboard is a difficult place to work.
CRT
Sep 10, 2007 at 3:12 PM
  • 75,988 POSTS
[quote:d1dbd06ad7="CRT"]1994 Nissan kingcab d21 102,000 miles - 4-cylinder - 5 spd manual
CRT[/quote:d1dbd06ad7]
You wanna perform a triple bypass on the starter interlock relay-just go find the black/yellow or black and pinky remove it from the starter-now go to the parts store and get a no.10 awg, wire and a push button-hook one end of this wire to the starter and take thru the firewall, position your push button on the dash for your reach hook-up the switch up then go back out of the firewall then straight to the battery positve terminal-there's other ways of doing it-this way is for the DIY's
Next step is function check: turn key to On,step clutch in and brake now push the button-did it work.
BTW you won't be needing the clutch switch down at the pedal-save it for a decor-
Good Luck
Sep 10, 2007 at 7:46 PM
Suggested Repair
The expert recommends a DIY starter-interlock bypass: disconnect the black/yellow or black/pink wire at the starter, run 10 AWG wire from battery positive through the firewall to a dash push button and then to the starter, and function-check with the key on, clutch and brake applied, and the button pressed. This leaves the clutch pedal switch unused.
Conversation Summary
The owner of a 1994 Nissan King Cab D21 manual reports an intermittent starter interlock. Clutch and switch adjustment helped briefly, then jumpering the switch wires did not. The expert suggests wiring a dash push button from battery positive to the starter to bypass the interlock and clutch switch, then performing a function check.
