Nissan Truck will not start
BOB GAGNE
Engine problem
Nissan Truck 4 cyl Four Wheel Drive Manual 187500 miles
The truck will turn over but no gas is getting to carb. he fuel pump works the fuel filter is ok the gas gets to the fuel filter in the engine but no gas gets to carb to start any suggestions
Jan 28, 2008 at 6:46 AM
2CARPRO JACK
  • 11,533 POSTS
If you unhook the fuel feed line will it pump fuel into a container?If so,sounds like the needle and seat is stuck down, not letting fuel into the float bowl. Might want to find a shop in your area that does carbs, these shops are getting rarer now days
Jan 28, 2008 at 11:39 PM
